How to erase the omg files? it makes my hdd full!! pls help
Guest Anonymous
u can simply check the directory that it stores it in by selecting the Tools Menu (in OpenMG) then to the CD Recording/Playing 1 tab...from there you will see a box 1/2 way down under the option Settings for CD Recording...that's basically the location of where the program stores the optimised files...copy and paste the directory to windows explorer and then it should open up that folder...within it should be another folder called Optimized Files...open that up and you will find all the ATRAC files located there...delete them as u wish... tongue.gif
