Anyone knows a good Cover Minidisc Software??
lkjhgpoi
I made labels by simply measuring the size of the minidisc label area and then creating a printing template within my HP software that came with my printer. All I have to do is tell the program what images I want it to print and it'll line them up. It gives relatively accurate previews of the image and it allows you to adjust them before printing. It's pretty cool stuff.
I don't know if this helps at all:
http://forums.minidisc.org/viewtopic.php?t...der=asc&start=0
Good luck!
