virtualchaos Posted September 14, 2003 Report Share Posted September 14, 2003 MY sony netmd Mz-N505 has broken, but I still have the fully operational usb cable, would I be able to save money by buying a Netmd without a cable, if so where? Can any MD recorder use the USB cable or am would i have to buy another Netmd.... thanks Quote Link to comment Share on other sites More sharing options...
Korgull Posted September 14, 2003 Report Share Posted September 14, 2003 Maybe on Ebay, but not much less than if it did have a USB cable. Quote Link to comment Share on other sites More sharing options...
mAjEsTiC Posted September 15, 2003 Report Share Posted September 15, 2003 Quote Can any MD recorder use the USB cable or am would i have to buy another Netmdwell only Sony NetMD capable recorders can use this cable and it also depends on the model as well...not entirely sure about the N910 but the N10 uses a different cable so it's pointless trying to use this USB cable on that unit...otherwise the N7xx series and below should use the same cable input as your N505 unit so it shouldn't be a problem using this cable with these units... Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 11, 2003 Report Share Posted November 11, 2003 I have the 710 with the Net MD USB cable. The mini digital camera I have (not made by Sony) uses exactly the same type of cable. I'm sure other mini USB devices will probably have the same. Quote Link to comment Share on other sites More sharing options...
mAjEsTiC Posted November 11, 2003 Report Share Posted November 11, 2003 yup i agree...so long as the cables match up (usb mini plug) then it should work np... Quote Link to comment Share on other sites More sharing options...
