"black box" with simple burner - need uilib.exe
Guest Anonymous
Guest Anonymous
Der all,
I gather from various message boards that I need to install sony's UI library to get rid of the black box that appears where the track listings should be. ANyone know where I can get a copy please? I did get one from Sony's site but it seems to be designed for Vaios and wouldn't install on my PC. Thanks in advance tongue.gif
a while ago i took everything necessary to install netmd stuff off my 707 cd. it was
the driver
the open mg module
simple burner
and uilib
and all the updates for everything.
its about 17 megs, and 13 compressed.
anyways i just made an installing archive for just the uilib and its 1.7 megs
its here
http://dcp.ath.cx/uilib
tell me if it works for you
  • 4 weeks later...
  • 1 year later...
I've got a netMD MiniDisc player bundled with OpenMG Jukebox only. I've had a lot of problems with OpenMG Jukebox.
So, I installed SonicStage 3 instead.
However, I find it more convenient to use Simple Burner to record my CD's to miniDisc in one operation.
I could download Simple Burner 1.0 but I could not find version 2.0.
Any download link is welcome.
Thanks !
check the "downloads section" on these forums (pictogram on the top right of the page) SB 2.? should be hosted there
greetings, Volta
