how can i understand_?
Guest Anonymous
Guest Anonymous
i m from turkey(sorry for my english)
maybe it is stupid question but i must learn it because i want sony mz-n710 and i never WANT 1,2mW+1,2mW (i want 5+5 mW)
how can i learn my md that eu or japan?(i dont have it yet)
is it written anywhere on the md?(for ezp back of md? )
for exp: made in eu or
made in japan??
can someone copy jpeg of it....... :cry:
i have seen here(turkey) some model that made in malaysia or taiwan...
are malaysia or taiwan, same as eu model ? or japan?
i m confused... :cry:
unfortunately i do not personally own this unit but i know of a friend that does and i've seen that it was made in malaysia...but purchased in australia and has a 5mW RMS per channel output...if i can catch him tomorrow at uni i mite be able to get a pic of the under side of the unit for you and post it up here...
Guest Anonymous
  Quote
made in japan??
also this question
i want learn best idea...pls help me.
i have 10.. gigs mp3 from kazaa and i ONLY USE my mp3 archive transfer to md(it will be mzn710) ,is it any copyright problem?
or will i buy sony dne1e cd-mp3 player???
what would you suggest?
which one are they good sound quallity?((dont forget,i copy my mp3 to md,not waw and ""mp3 cd-player" read mp3 from cd ,same source....yes,i know md player keep it more qualitty,but source is Same.
as i know,what ever you do to mp3(f.e.:convert as waw)it always keep same quallity ..= mp3 ,you just lose more mb..(4mb willbe 40mb))
is it false?
(sorry for my english again :cry: )
  Quote
this should be fine...it won't have any problems transfering across these files that you downloaded unless they specifically say that they are copyrighted...
  Quote
well this is up to you and depends whether or not you want an MD or a mp3 discman...personally i prefer my MD because of it's size and flexibility and since i own both an MD and a mp3 discman i can say that the choice depends on whether or not you care about putting massive amounts of songs onto a medium or not + depends on what you find convenient in copying songs to that media...i.e. mp3 cd's are more easier to make than MD's through NetMD since it's just a drag a drop burn process rather than convertion to ATRAC3 and then transfering across...
  Quote
is it false?
well if you say take a 128kbps encoded mp3 and convert it to wav file then it won't sound as good as say the original wav file that was ripped from a CD if that's what you are getting at...it doesn't really make that much of a difference since mp3 compression is lossy and most of the data from the original cda track is usually lost through compression so even when you encode it in wav it can't make up for the information lost during the encoding to mp3...
Guest Anonymous
i really thanx for your answer mAjEsTiC smile.gif and than
i found new question..
i really worry for sound quallity...
which sound quality is better??
with 192 kbs in mp3 discman(sony ne10e mp3cd ply.) or lp2((from192 kbs mp3))with md player?
and i spend really time for recording..16x sad.gif .((isn't lp2 132 kbs :cry: ))
with mp3 cd player i get 800mb(about 10 albums) or with lp2 3-4 albums...i think mp3 discman have more sound outputsurely:
if md(lp2 mode) have better sound than 192kbs in mp3 cd player,it wont be problem..because sound quallity is everything for me biggrin.gif
i really need help because i never use one of them..
  Quote
and i spend really time for recording..16x  .((isn't lp2 132 kbs  ))
well i don't mind listening to LP2 recording or 192kbps encoded mp3's...but personally i have never actually tried comparing listening to a 192kbps mp3 cd and an lp2 md....i might try that out a little later when i have more time but in terms of CD's holding more than MD's this is true...MD can only hold about 150MB compared with 700MB on a CD...the new mp3 discmans from Sony i haven't actually had time to listen to them yet but i will try and do the comparison between my Panasonic SL-CT800 mp3 discman (record a CD full of 192kbps encoded mp3's) and my Sharp DS8 player (using an MD recorded in LP2 through NetMD transfer from Sonicstage/OpenMG) both using the Sony MDR-E888 earbuds connected to both units....i'll try to do this ASAP and post my findings and opinions...
