Net-Md MZ-N707.....missing screws!
Appleman10
I run a lot with my n707, and I guess the vibration from my running has caused two of the little screws on the door of the md to pop out, making opening and closing the door crooked and tedious. Is there anywhere I could buy one of these screws? What do you recomend I do?
P.S. I am still covered under warrenty. (purchased last November)
If you need a quick fix or Sony repair doesn't pan out (warranty is good--try to use it), poke about on the unit and see if there are a couple screws you can spare from elsewhere (perhaps the screw nearest the AC input) to keep the lid solid until you can get more screws.
If you're completely stumped, try your local eye doctor and see if some eyeglass screws might do the trick.
