MD Dillema
Guest Anonymous
Guest Anonymous
hi thre i have a huge dillema because i have 2 MD to choose and i can't decide which one is better.
i'm consider beetween mz-n707 and mz-r909
i will be glad if someone could give me good advice...
there r pros and cons 4 both models...
i'll do a quick comparison of the 2...R909 is lighter (full aluminium shell)and smaller (N707 has a big lump at the back where the battery goes and is made half out of plastic and the front panel out of metal) + has a longer battery life (uses both NiMH + AA whereas N707 uses 1xAA)...also the R909 has a 3 line LCD display on the main unit and a backlit remote (and all the bells and whistles you come to expect in a flagship model from Sony) where as the N707 has a 1 line LCD display and a non-backlit remote...tho it does utilise NetMD which is something the R909 does not have...
the R909 is somewhat of a better unit overall but if you do want NetMD to transfer music from PC -> MD faster than real-time then you're better off with the N707 and just buy a backlit remote if you want that functionality...ultimately the choice is urs...both r relatively good units...
