satanas Posted October 21, 2003 Report Share Posted October 21, 2003 Hi! I have a Sony MZN510 and I think the remote sucks, I want to buy a new one with a display on it. Audiocubes got a lot of remotes but I don't really know which one to get. These are the once they got -> REMOTES What I'm looking for is an remote that can control all of the functions of the MD including ability to scroll the song info and more. Please help me to select the right one. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
mAjEsTiC Posted October 21, 2003 Report Share Posted October 21, 2003 from looking at that site i would say that either the 33EL or 35ELK will work on the N510 unit you have...but the 35ELK is useless if you bought ur unit outside of japan as it does not have kanji support so the feature on this remote is useless...so the 33EL will do... Quote Link to comment Share on other sites More sharing options...
satanas Posted October 21, 2003 Author Report Share Posted October 21, 2003 Thanks for the reply. Do you know if the buttons will be remaped if I buy the 33EL remote? Quote Link to comment Share on other sites More sharing options...
mAjEsTiC Posted October 22, 2003 Report Share Posted October 22, 2003 not 100% sure but it works on the N710 unit fine...this i've tested already...not too sure on the N510 though... Quote Link to comment Share on other sites More sharing options...
