RaBiD Posted October 25, 2003 Report Share Posted October 25, 2003 hi, i have a mz-n707. I havent done anything to it like hacks etc. When i record something on netmd it seems to work fine.. i can edit all the tracks etc. But then i take the cable out, then it plays normally. But the problem is when it goes into standby mode, then i press play it says blank disc when ive just recorded something on it about 30 seconds eariler. It hasnt always done this.. only recently but now it does it every time. Please help, thanks Quote Link to comment Share on other sites More sharing options...
mAjEsTiC Posted October 25, 2003 Report Share Posted October 25, 2003 it could be a lens misallignment...because my N1 is in for repairs atm after finding out that it does exactly what you described...and if ur unit is still under warranty, i'd suggest u get it checked out to see if that's the problem... Quote Link to comment Share on other sites More sharing options...
