How do i connect to computer?
Guest Anonymous
Guest Anonymous
I have a minidisc player with a PC link cable, but i don't know what software to use to put music onto the MD.
Any help would be awesome,
I have a Sony MZ-R700 with windows XP.
Also does anyone know if there is any mac OS X apps out there?
u can't transfer faster than real-time with the R700 since it's not NetMD capable...using the PC link just gives the unit a digital output and you have to record using normal methods (i.e. play a song in like winamp or a similar program and then slide the recording switch on the unit)...if the PC link came with software then use that...
