fortgjort Posted October 27, 2003 Report Share Posted October 27, 2003 Hi! I have just bought a Sony Net MD MZ-N707 Type-R. MP3 files that i transfer to my unit can be played on the unit as normal. But if i insert the disc in my Sont MD Deck MDS-JE510 the display shows LP:<some song> and there is "absolute silence". Is atrac3 not possible to play on my MD Deck. Is there anything I can do? I've tried to look for details on www.minidisc.org, but Im still confused. By the spec. it looks like my MD Deck has an ATRAC4 chip installed. Hope to hear from u! .forgjort Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted October 27, 2003 Report Share Posted October 27, 2003 fortgjort, I am by far an MD expert here... But in lamen's terms heres what happened. You've recorded a Minidisc ineither LP2 or LP4 and your trying to play it on an MD deck that doesn't support it. You will need to record MDs in SP mode in order to play them on your deck. Your MZ-N707 has MDLP and is able to record in SP, LP2, and LP4 modes. Your MD Deck sounds like it is Pre-MDLP erea because from what you've explained it sounds like it does the same thing my MD deck does when I put an MD that was recorded with MDLP in it. When you record to you MZ-N707, make sure you're doing it in SP mode. This will allow you to listen to it on your MD deck as well. Quote Link to comment Share on other sites More sharing options...
fortgjort Posted October 28, 2003 Author Report Share Posted October 28, 2003 If that is the case....does anyone know any good pc software that let me transfer mp3 files from the computer -> to the Net MD in SP mode. Im currently using Realplayer, but this software uses the OpenMG software to transfer as far as I know. When transfering files here it looks like I have to choose one of the LP modes.... Or am I wrong? .fortgjort Quote Link to comment Share on other sites More sharing options...
mAjEsTiC Posted October 29, 2003 Report Share Posted October 29, 2003 so far there's no program that i'm aware of that will enable us to transfer music from the PC -> MD in SP mode...all the programs that i've used transfer only in LP modes and to record SP it has to be done in real-time using old school methods of hooking cables up... Quote Link to comment Share on other sites More sharing options...
just_visiting Posted November 3, 2003 Report Share Posted November 3, 2003 Quote If that is the case....does anyone know any good pc software that let me transfer mp3 files from the computer -> to the Net MD in SP mode. Im currently using Realplayer, but this software uses the OpenMG software to transfer as far as I know. When transfering files here it looks like I have to choose one of the LP modes.... Or am I wrong? .fortgjortOpenMG/Sonicstage will allow you to transfer in SP mode but a "true" SP quality. SP mode in OpenMG/Sonicstage is actually a LP2 quality. Quote Link to comment Share on other sites More sharing options...
mAjEsTiC Posted November 3, 2003 Report Share Posted November 3, 2003 Quote OpenMG/Sonicstage will allow you to transfer in SP mode but a "true" SP quality. SP mode in OpenMG/Sonicstage is actually a LP2 quality.um...shouldn't the SP in OpenMG/SonicStage be a slightly enhanced LP2 mode (i.e. higher bit rate LP2 ATRAC3 compression)??? rather than it being LP2 quality exactly??? since that's how the bit rate is approx. shown in the program...(lower than "true" SP but slightly higher than LP2...) Quote Link to comment Share on other sites More sharing options...
