ac adapter for panasonic sj mr200
Guest Anonymous
Guest Anonymous
ive recently come into posession of an md recorder for a great price, which i want to use for field recording, incidental sounds and stuff. its an older model panasonic sj mr200.
trouble is theres no AC adapter, and it doesnt have the little screw on thing to attach an AA battery. none of the local electronics stores have multi votage adapters suitable, cos the required input is only 1.8v, and the adapters only go down to 3v. Will recharging with a 3v damage the unit/battery? is there anywhere online where i can purchase a suitable ac adapter? also how would i find out what currrent is nominal for recharging?
im in NZ
thanks for your help
