advice for taping concerts
Guest Anonymous
Guest Anonymous
Hi I am interested in taping concerts with a Minidisc Recorder. From small clubs to arenas. What would one recommend for me to purchase???
I would like advice on a suitable Minidisc Recorder and Mic. I dont really want to spend an arm and a leg But I would like a very good stereo mic.
Thanks for the help
lildevil
get a Sharp recorder (any would be fine since they're all really good recorders ~ depending on you're budget will depend on the model but even the cheapest one is sufficient enough to meet your demands i would think...unless u're planning on using this as a pro recording then i'm not too sure) but for mics generally i use either Sennheisers or Sony...again doesn't really matter which one but look for the ones that support Plug-In power (i.e. non-powered amp) and whether or not they're omni-directional, uni-directional etc...models that i use from Sony include the ECMDS70P, ECMMS907 and ECMZS90...all are very good for recording...
