Guest Anonymous Posted November 5, 2003 Report Share Posted November 5, 2003 I have Sony MZ-N10 and ECM-F01 microphone. Any attempt to dubb live recording from the MD to tape recorder resulted in the one channel recording on the tape cassette (only L channel). I tried different things but nothing seemed to help. Because the microphone is MONO, I recorded to the MD in the MONO mode, and when I listened to this recording from the MD I could hear both channels. However, when I tried to transfer it with the mono cord, stereo cord or stereo cord with mono adaptors, the sound on the tape was again on the one-channel only. I don't care that recording is mono, I just want it to be hearable on both ears, because transcriber will probably lose her mind otherwise... Thanks for your suggestions! Quote Link to comment Share on other sites More sharing options...
sudden Posted November 7, 2003 Report Share Posted November 7, 2003 Here is a easy trick. Pull out the cord from the plug slowly, at one point the connectors will overlap and mono audio will go to both channels. It may be a little lower volume but just turn up record level and it's fine again. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 7, 2003 Report Share Posted November 7, 2003 Thanks, I'll try this, and hopefully it'll work. Quote Link to comment Share on other sites More sharing options...
H22CRXSOL Posted November 9, 2003 Report Share Posted November 9, 2003 Also, on your recording software on your computer, make sure it's set to record in mono as well. Quote Link to comment Share on other sites More sharing options...
