MZ-NF810/SonicStage 1.5.53 Where did my checked in songs go?
Huw
I recorded some songs to my MD from CD the other day and decided to test the check-in feature of sonic stage, i created a new playlist and then checked the songs i wanted in. The transfer occured ok and the track was deleted from the MD, but no songs appeared in the new playlist of on my pc's hdd, any ideas?
Thanks in adavnce
Huw
if the files have already been encoded and transfered they would be stored under a specific folder that SonicStage creates for you...(go to Menu down the bottom left of the screen and select the Option... option...then from there select the Location to save the recorded files) and it should show you where the files that have been encoded are located...just import the files into SonicStage again...
