Differences: EX71SL and EX51SL
Guest Anonymous
Guest Anonymous
Hi guys first time posting...
anyways I have researched a bit and found out that the EX71SL and EX51SL have the same specs but differences in price, being the EX71SL more expensive.
to anyone who has tried both or has any of them:
-which is more comfortable: 71 or 51
-which has louder bass :71 or 51
-which has better duribility: 71 or 51 (as far as im concerned my friend has the 71 and it has a little rip on the white part (not the buds).
and lastly which do you think I should get, considering i have a MZN710. thanks biggrin.gif
the diff between the 71 and the 51 is that the 71 is made out of rubber whereas the 51 is made out of plastic...that's basically more or less the difference...sound quality is more or less similar with i think the 71 having slightly punchier bass...and N1's are more or less phased out in sydeny...if you do want to look for a new MD unit go down to near the QVB and check out the stores there...i usually go to either HomeZone or G&V Imaging...both are basically across the rd to each other and allow you to bargain... tongue.gif
