long loading time sharp mt899
Guest Anonymous
Guest Anonymous
i accidently dropped my friends sharp mt899 and it has two dents on the back, well anyway when i put a disc in it, the remote says 'TOC READ' for about 30 seconds before playing a song, why this happens i don't know. It used to not take that long to startup, so does anyone know a possible solution to fix this problem?
  • 7 months later...
I dare say, you have no choice but to take it to a repairer to have it looked at.
I bet, that not too long now, it won't play or record.
Try using the NetMD a few times to record off the computer. Are you getting buzzing-like sounds in the recording? Yes? Well that's because the lens housing unit is cracked, which happens quite often when these units are dropped.
It makes me very angry about MD units. It happened to me and I feel ripped off!
