dazzjazz Posted November 24, 2003 Report Share Posted November 24, 2003 My N10 seems to be constantly recharging. The display is not showing 'mins left' to fully charged but the little battery icon keeps ticking over. Every now and then it will stop but if I remove it from the cradle and replace it (without use) it will start charging again. The unit is connected to my PC via the USB cable while this whole recharging thing is goin on. Any ideas ? Dazzjazz Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 27, 2003 Report Share Posted November 27, 2003 I have just the opposite problem. My N-10 only charges for 1 hour and then nothing will get it to continue to charge. I think that this severely limits the play/record time. If you unplug the USB plug from the charging cradle you will get the remaining charge time to display. Quote Link to comment Share on other sites More sharing options...
