Eric Posted November 26, 2003 Report Share Posted November 26, 2003 Obviously I am new to md's. But I desperately need help. I have a sony MZ-R70 and would like to transfer the live recordings onto my computer. The md only has an optical in, mic in, and 2 headphone jacks. How do I get the recordings onto my computer? The people at sony said it can't be done. And does anyone have any suggestions on cheap microphones? And are there any hacks for this model? Thanks for the help because I have no prior experience with md's. Quote Link to comment Share on other sites More sharing options...
Kuoi Posted November 27, 2003 Report Share Posted November 27, 2003 From the headphone jack to your Line-in from your PC . That's how I do it anyway , I can't figure out why it can't be done. You can use the mic-input of your PC , but you'l have much distortion then. Succes , Kuoi Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 27, 2003 Report Share Posted November 27, 2003 To get the recordings on computer, run a cable from the headphone output of the MD into the mic in/line-in of your computer. The get a free program like GoldWave (search for it at www.download.com) and play the MD back on computer and press record on GoldWave. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 27, 2003 Report Share Posted November 27, 2003 Do you know what the cable is called? I'm a beginner. Also, do you no if it is possible if you don't have a mic input on your pc, all I have is usb, and firewire inputs? I have a speaker and headphone out jack. Thanks again for all the help, Quote Link to comment Share on other sites More sharing options...
mAjEsTiC Posted November 28, 2003 Report Share Posted November 28, 2003 u use the Line IN jack on your PC's soundcard...i think most of the soundcards out there already have it...the cable is just a typical double ended 3.5mm stereo plug that you can find in most electronic accessory stores... Quote Link to comment Share on other sites More sharing options...
