MZ-N505 Hack Failure...No available solutions works!Plz help
judagrumme
Hi all...
I tried the hack from the "Wild 505/707 hack" topic, but i made a mistake during the configuration, and the buttons are messed up ( Play = Vol Up, Stop = Vol Down, and so on...)
I tried to get back in the service mode using the remote, but it doesn't work...I tried tu push the "Group" button instead of the pause, but it doesn't work either...
Any solutions ? I'm afrzid I've broken down my NetMD...Plz Help thanks !
Another question : While doing the manipulation with the remote, do I have to switch the "Hold" button of the remote on "ON" too ?
Thanks to any helper...
Try to enter the service menu through the remote.
You should be able to find the instructions through the service manual:
http://www.minidisc.org/manuals/sony/servi...vice_manual.pdf
To reset all the values in the service menu, here is a chart:
http://www.minidisc.org/manuals/sony/servi.../sony008035.pdf
That should give you the power to fix it... if you can get into the menu
just figure out what buttons do what and you'll be fine somehow.
Good luck~
(now, if only someone could help me out with my problem:
http://forums.minidisc.org/viewtopic.php?t=3333)
