Checking in Songs BUT playlists been deleted..
Guest Anonymous
Guest Anonymous
I have deleted all my original playlists due to hard drive space, but now find that if I check in songs, they totally disappear!
Is there any way of re-saving the files when they check in?
Can`t seem to find the answer to this!
Nope, not that I know of... You need the files imported into SonicStage or OpenMG... So tough luck I guess... You will have to re-import them into SonicStage. Hard drives are cheap these days, why not buy one? But if you are in financial crises then there really is no choice but what your music dissappear...
