siberia323 Posted December 17, 2003 Report Share Posted December 17, 2003 I have a Net MD Walkman MZ-NE410. I bought this unit because I would like to transfer some MP3 files from my computer to the unit. The problem I am having is that the software that came with the unit says that the files are incompatible with the unit. It said something about the MP3 files being at the wrong bit rate. Finally, the question. Is there any way to change the bit rate of the MP3 files? I am not the person recording the MP3 files, I receive the files by email. Quote Link to comment Share on other sites More sharing options...
BerkY Posted December 17, 2003 Report Share Posted December 17, 2003 Well the bitrate has to be higher than 128kbits and at 44.1 Khz (no matter the bitrate). You can change the bitrate. First you would have to convert the file to WAV and then change it back to 128kbits MP3. You will need an MP3 encoder program like LAME. I use Creative's own program which does the job... cheers BerkY Quote Link to comment Share on other sites More sharing options...
siberia323 Posted December 17, 2003 Author Report Share Posted December 17, 2003 If for some reason the MP3 isn't at 44.1 Khz, is there a way to change that too? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 17, 2003 Report Share Posted December 17, 2003 Use Winamp 2.9X with its Disk Writer plug-in to write WAV files from those MP3's. Make sure it's set to force 44kHz/16-bit/Stereo. Then rather than sending those MP3's through NetMD, send the WAV's. Quote Link to comment Share on other sites More sharing options...
