MZN-505 and Recording and ...
Guest Anonymous
Guest Anonymous
Hi,
Looking at buying a recordable MD and have my eyes on this particular model but need to be sure before i plunk down the coin.
I have perused this forum and believe i have my answers .. but need to make sure ... again .. before i spend money i don't have.
My primary use for this recorder is to record band practice and the like. It doesn't have to be perfect ... but it should sound nice enough to get the gist of what happens during practice.
Questions/Assumptions:
- I can record live as long as i have a powered mic since the 505 doesn't have a mic in. ?
- Recording using the line-in and powered mic should work "as well" as using a recorder that has a mic-in. ?
- I can adjust the input level on the MD recorder. But I cannot adjust it on the fly. ?
- The 505 is the cheapest unit that can do these things. ?
- For what i am trying to accomplish ... (live recordings from a powered mic with adjustable level control) the 505 unit should work well for me. ?? !! ??
- Is there something that i haven't thought of that should sway my opinion to or away from this unit?
Again .. I'm just trying to be sure that i don't get huge buyers remorse from purchasing a MD recorder that doesn't work for my situation.
Any info is helpful.
thank you
Dig
heyy there,
i'll answer ur q's 1st b4 i elaborate on them...
yup that's right 4 all 3 q's...
from Sony yes...
the 505 unit would work alright but i would recommend that u take a look at the Sharp DR470 or DR420 units...they offer more features that u'd like to have such as adjusting levels on the fly as well as a powered mic input...that and Sharp recorders are reknown for making really good units 4 live recording...IMO their quality of live recording are unsurpassed by any other company including Sony...
feel free to ask any other questions you might have...
Guest Anonymous
thank you for your answers mAjEsTiC.
where would be the best (read: cheapest) place for me to purchase a sharp unit? far as i can tell they are not for sale in the gool ol' us of a.
dig
