how to record from mz-n1 to cd
Guest Anonymous
you have to get a normal dual 3.5mm plug analogue stereo cable and connect it from the LINE OUT of your unit to the LINE IN of the soundcard and use a program such as WinNMD to get the tracks back to your computer with titles...then it should be saved as either an mp3 or a wav file on your PC...from there just open up your burning program and compile a cd with those files...
