WMA Files
KLank
  • 3 months later...
Hi Ken,
There is a way of converting WMA -> MP3, what you need is dBpowerAMP. You can download it from here. That is the simple music conversion tool, then you need the WMA codec for it which you can get from here.
Install the codec and then within dBpowerAMP you should be able to convert WMA -> MP3. The only problem I have found with it is that it doesnt write the tags, so these need to be put in after.
Hope this helps,
Mark
