Guest Anonymous Posted January 30, 2004 Report Share Posted January 30, 2004 HEllo all I have a Mz-N707 little friend, and there's so much music to copy... Yet I bump again and again into this strange problem- While I try to record specific files (all from the same album in this case) the transfer gets stuck on 67% and will go no further. This does not happen with other files, and I cant figure it out. Can somebody please help? Thankks in advance! ilsh Quote Link to comment Share on other sites More sharing options...
mAjEsTiC Posted January 30, 2004 Report Share Posted January 30, 2004 try converting the files to a .wav then try transfering again or just use a different program to transfer across... Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 30, 2004 Report Share Posted January 30, 2004 >or just use a different program to transfer across... if only someone would make a different program to convert .mp3 to ATRAC3 BOYCOTT SONY Quote Link to comment Share on other sites More sharing options...
highlandsun Posted January 31, 2004 Report Share Posted January 31, 2004 Sounds like it's choking on a part of the music. If you don't mind, I'd like to get a copy of the file that's causing the problem so I can play with it. In the meantime, I've generated a short WAV file that caused my ATRAC3 encoder to crash. I got around it by editing the WAV file and normalizing the volume to 90%. This tells me there were some samples hitting full volume in the 16 bit samples, and the codec was getting a math overflow error. It's not enough to have a program to convert any other audio format to ATRAC3. I already have that. You also have to store it in OMG format, or figure out the encryption being used in the USB download... Quote Link to comment Share on other sites More sharing options...
