Guest Anonymous Posted February 22, 2004 Report Share Posted February 22, 2004 The buttons are all wierd.. FF button keep working as a REwind button.. How do I fix it? I am getting a new remote.. will that fix the problem? or do I have to open up the case? Quote Link to comment Share on other sites More sharing options...
onlykaria Posted February 22, 2004 Report Share Posted February 22, 2004 you know the same thing happened to me. i actually ended up having to take it back. i think its a program with the construction. i do think that if you lock the unit and control it only with the remote itll fix the problem. but i am not 100% sure on this. Quote Link to comment Share on other sites More sharing options...
darkfusion Posted February 22, 2004 Report Share Posted February 22, 2004 This problem is quite common in MZ-N505's, I know several people that have experianced this after time. It *could* be due to dust build up, in which case a good idea would be to grab a can of compressed air and try blowing it around the buttons. The reason I suggest this fix is because I know of a similar case in which it's fixed the same problem on an MD-DR7, however the problem may be down to the actual firmware. If that fails, you can try opening it (providing the warranty has expired anyway) and try giving it all a clean, getting rid of the dust etc. around the buttons. If this doesn't work, I doubt it's worth getting it repaired by Sony as you could probably pick up a higher model on eBay for the same amount as the repair costs. Good luck! Quote Link to comment Share on other sites More sharing options...
porio Posted March 19, 2004 Report Share Posted March 19, 2004 Hi, I downloaded the service manual for the N505. Is there anything else that I should know before opening the unit? (or before trying to re-assemble it?) Thanks! Quote Link to comment Share on other sites More sharing options...
