Moving the OpenMG Jukebox to another PC
stenaxel
Of course there is. You have to use the Open MG Backup tool that comes with Open MG Jukebox. It will make a backup of the music database files. This can then be restored on a new PC. The only proviso is that you have to be connected to the internet during the restore process (perhaps also the backup process, I can't remember, but definitely during the restore) so it can perform some kind of validation. I don't know what it does during this step, but I know it does not require you to have your product registered.
The other consideration is the backup media. Depending on the size of your database, you might have an issue regarding what you backup on to. You could backup onto the existing hard disk if there is enough space then put the old disc in the new PC as a slave from which to restore the database. You can backup to any other media as well, such as CD-R or DVD-RW etc.
Also note, the check out count is backed up also, so if you check in all your music before you back up, you can restore your checkout count at some point in the future, but checking everything in and back out again is pretty tedious.
I have done this on several occasions and can vouch for it.
Also, kurisu is mistaken, you can restore the backup to any number of PC's. I have had a database on as many as 3 PC's at one time and typically have a copy on my desktop as well as my laptop. These computers are often networked and there is no conflict.
