stevo Posted March 23, 2004 Report Share Posted March 23, 2004 Hello. Just deleted openmg and simple burner and got SS2 as this forum suggested. Its looks good and seems to be less of a system hog than Openmg anyway. Also the unlimited checkouts is nice. But why oh why - can I not delete songs on my md unit or deck that I recorded using SS2. i just tried it a minute ago and got the old TRPROT message. Very annoying cause if I need to delete a track to make space for something when I am not at home - i can't. Thats what i liked about simple burner - no crappy track protection. Can I use simple burner with SS2 installed? Its very annoyinh and I can't even see the point of this protection. Also - the 256kps option for recording - is that purely for HiMD? Quote Link to comment Share on other sites More sharing options...
mAjEsTiC Posted March 25, 2004 Report Share Posted March 25, 2004 i think the 256kbps is meant only for HiMD's and NOT normal NetMD's... Quote Link to comment Share on other sites More sharing options...
iceeedtea Posted March 25, 2004 Report Share Posted March 25, 2004 Also - the 256kps option for recording - is that purely for HiMD?Yes and no. It will not work for the "older" generation of NetMD units, but it will work for Hi-MD. It is not purely for Hi-MD, as it has been reported to work on Sony ATRAC3+ PDCPs. Can I use simple burner with SS2 installed?Yes. If you're feeling brave, and don't mind issues/not being able to read the text in the program, take a look at this. It does not work properly on English operating systems; then again, it should be simple enough to figure out what does what in the program, no? Quote Link to comment Share on other sites More sharing options...
