mwma Posted April 12, 2004 Report Share Posted April 12, 2004 I use Nero to create an audio cd as an image and save it on my desktop. Then I load it using ImageDrive. Next I open NetMD Simple Burner and load the image. If the image is quite large, say over 120 minutes or so, I get an error on Simple Burner, although it doesn't overtly say "error". What I get is a listing of all the songs, with the correct timing on the right hand side. However, for the last two songs I'll get a reading like this: track 25 157:25 track 26 -144:32 Anyone else have this problem? Is this a Simple Burner thing? Or a Nero thing? Or an ImageDrive thing? Is there a way to load 150 minutes of songs onto a minidisc without creating two images and burning each image onto the minidisc separately? cheers. mitch Quote Link to comment Share on other sites More sharing options...
iceeedtea Posted April 12, 2004 Report Share Posted April 12, 2004 Try to utilize the program which is this. It simplifies transfer by using Simple Burner. Not sure if that will help you with the situation. Don't make images over 160 minutes. Why not make seperate 80 minute images? Quote Link to comment Share on other sites More sharing options...
mwma Posted April 14, 2004 Author Report Share Posted April 14, 2004 Quote Try to utilize the program which is this. It simplifies transfer by using Simple Burner. Not sure if that will help you with the situation. Don't make images over 160 minutes. Why not make seperate 80 minute images?Nope. tried it. still get the same goofy timing on Simple Burner. Must be a Simple Burner issue. I guess I have no alternative but to create 2 separate images. It's not really a problem with creating 2 separate images, it's about getting a whole show, which usually runs 120 -150 minutes, burned onto the minidisc in one shot....not having to break it up into 2 pieces. thanks. Quote Link to comment Share on other sites More sharing options...
