mikemo Posted April 24, 2004 Report Share Posted April 24, 2004 Hello all. I hope I can find some assistance on this problem. It really isn't a big deal but I'm "on a mission" to figure out what is going on. A CD that I bought had an extra track for download off the web. You put your original cd in the drive and it checks that you acutally bought it (what a concept!), then you can download the extra track. The track comes down as a WMA file. I can import it in to SonicStage without conversion, but if I try to import with conversion to ATRAC3 it fails. If I import it as a native WMA, it works, until I try to check it in to the MD player, then it fails (presumably when it trys to convert from wma to atrac). It says "detected file can not be imported" and "only converted files are registered". I'm assuming that I'm running in to some copy protection. Can I get around this or should I just delete the file. BTW, it does play properly thru the windows media player. Thanks for the assistance. Mikemo Quote Link to comment Share on other sites More sharing options...
nexgod Posted April 24, 2004 Report Share Posted April 24, 2004 have you tried encoding it in MP3? hmm actually it might have some sort of protection, but if u use search on these boards, im sure you will find a way pass it Quote Link to comment Share on other sites More sharing options...
mikemo Posted April 24, 2004 Author Report Share Posted April 24, 2004 I would try that (encoding as mp3) but I don't know how to do that. It is odd, but when I import it in to SS, it shows 0 checkouts remaining... Any ideas? Quote Link to comment Share on other sites More sharing options...
colp Posted April 24, 2004 Report Share Posted April 24, 2004 I experienced something similar. So I burnt the WMA tracks to CD using Windows Media Player, then I had no problem importing the tracks through Sonicstage from the CD. Hope this helps. Col Quote Link to comment Share on other sites More sharing options...
mikemo Posted April 27, 2004 Author Report Share Posted April 27, 2004 Seemed kind of hokey, but it worked. Thank you for the tip! Quote Link to comment Share on other sites More sharing options...
