recharging sony nf810ck
mariusursache
hi
i just bought a used sony nf810ck and it came with a game-boy (3v) dc adapter. can i use this to charge the internal acc? when charging, i should see a battery sign or something on display? (like when you charge your cellphone).
if i start the md (play) when "it's charging" i see the battery sign blinking very fast and the music stops.
does anyone have any hints/answers?
thanks
marius
the Sony charger that came with my unit outputs 500mA 3V DC...and it looks like that that adaptor isn't charging ur unit as you will see the battery meter start increasing repeatedly to indicate charging...and since u see the battery sign blinking very fast and the music stops it could probably mean that it's not charging the unit and your battery is dead...
I think I need a more "powerfull" adapter (at least 500mA).
Meanwhile, I bought 2 acc (1400mA - NH-14WM like) and a charger for them. So problem ( partialy) solved.
