ted238 Posted May 21, 2004 Report Share Posted May 21, 2004 First time poster... and thanks for all the sticky info so far! I sing with a Barbershop chorus, and I'd like to record our (better) rehearsals and upload them to the chorus web site in MP3 format for members to listen to if they wish. According to Sony tech support, the software supplied with the units will allow digital upload to PC in either the raw format or ATRAC3 format depending on how it was recorded. The fellow I was talking to also said that the software would allow you to convert these proprietary formats to MP3 on the PC. I couldn't find confirmation of this latter statment (MP3 conversion) in any of the earlier posts, does anyone know if this is the case? It would make it very useful for us if true. Thanks, Ted Quote Link to comment Share on other sites More sharing options...
The_Stamp Posted May 22, 2004 Report Share Posted May 22, 2004 actually, the answer is really foggy. Sony Tech said that you can export from sonicstage?!?!?!? if thats true, then, then, THEN, I WOULD SCREAM "COOOL!!!" Quote Link to comment Share on other sites More sharing options...
