HELP USING STAGE VER 1.5
Mills123
Hi, could someone help me please!
I have only just recently got my minidisc player(MZ-N510) and when I first started using the sonic styage software with it, it was fine. But now evry time i try to copy songs from a CD to the music drive it says: the songs could not be transfered because the destination is too full. What does this mean? I can copy songs from my computer(kazaa) to my mini-disc player with no problem, Just not from a CD! could someone help me please??
Thank-You!
I can think of two possibilities: Your hard drive is too full (easy to check) or perhaps the CD has some kind of copy protection and the error message is just too dumb to give you the right story. Do you have much HDD space left on the drive partition where the files are being kept? The default is the C drive, which on many PC's now is small to enable recovery with a second larger partition being a "D drive" with lots of free space. Does the problem occur with all CD's or just one?
If Leland can't assist you, and in the long run you hit "dead-ends" please do consider Sonicstage 2. To check if your hard drive is full, open "My Computer" on the desktop and highlight your drives. It should list in the status bar, or the info listing on the left the capacity of the drive. If not, right click the drive and go to properties.
