Software for MD MZ-R70
XBOX-MEMBER
The "new" software won't work with the R70. AFAIK the R70 just uses the USB cable with a DAC to make audio recordings from computers into a LINE In source. This process will always be real-time and cannot be sped up.
Unless you REALLY need the speed, simply plug in the PC-Link as usual, and record the MP3. However, play the MP3 in FAST FORWARD!!! Now your MP3's will not only record faster, but they will also play back faster! What a time saver! [/just kidding]
To summarize, you can't make your r70 record faster.
Yeah it means it'll convert 48kHz sample rates from whatever optical source you're recording from, which is pretty meaningless since CDs are already at 44.1kHz so no sample rate conversion is needed.
24-bit ATRAC is just the bit width that's employed in the ATRAC DSP. All modern units are 24-bit, only the first generation Sony ATRAC DSPs were 20-bit.
:smile: ur a funny fellow ..
i got a MZR70 n i still record the snail way but when i'm going to sleep :wink: uhh 1:1 transfer is like real time
the Xitel converter converts the signal from the usb to optical then u plug ur optical cable to it BAM u got digital audio signal.. plug to ur optical in in ur unit n slide the record button n WAM ur recording in real time :smile: just digitally way kwel.. as for the p500 i don't really know what that is sorry
but the DG2 just over rides the signal to ur sound card n channel it through the usb to the converter n out to optical that's all it does really...the cool thing about it is that u can have ur list of tracks in say windows media player or music match n cuz ur recording digitally track marks will b inserted automatically
here's a lil review on it http://tech-report.com/reviews/2001q4/xite...g2/index.x?pg=1
uhh it costs bout $50 back in the day i'm sure u can get it for way less now
in terms of just using the NET MD it will work but using the MDLP compression when recording the dics i'm sorry but it won't work cuz that Sharp unit doesn't support MDLP
pay close attention to MDLP (minidisc long play) where u got lp2 n lp4 moods of compressing.. the audio is compressed so allow more music to fit on a disc ok.. but if u record in Sterio which even using the NET MD function will b close to real time recording cuz it only record at some 1.8X ..
