Manowar Posted June 2, 2004 Report Share Posted June 2, 2004 Hi to all i have a NetMD minidisc, and i'd link to put more than 160 minutes on a 80 mins minidisc in LP2 mode, as i did using my "old" MDLP minidisc using an optical cable. I just need a couple of minutes more (164 at max) just to be able to put 3 cds on an 80 mins minidisc. With USB and SonicStage / Simpleburner this seems impossible....someone knows a trick / tip / workaround? Thanx in advance Manowar Quote Link to comment Share on other sites More sharing options...
Christopher Posted June 2, 2004 Report Share Posted June 2, 2004 Welcome, friend. :happy: I think you may want to try putting one track in LP4 - perhaps one that isn't so desireable as the rest? Here's a calculator to assist you, if necessary: http://ravn.net/md/mdcal.htm Quote Link to comment Share on other sites More sharing options...
Manowar Posted June 2, 2004 Author Report Share Posted June 2, 2004 Thanks for the suggestion and the valuable link kurisu! Anyway i'd like to avoid LP4 compression since it is too "metallic". I belive that the limit of EXACTLY 160 minutes for 80 mics MD, is *only* in the Software...some maybe it can be "hacked" in some way (beacuse i saw - using digital 1:1 transfers - that MD are normally 30/60 sec longer that what reported on the label) Other suggestions? Quote Link to comment Share on other sites More sharing options...
crazeybt1 Posted June 5, 2004 Report Share Posted June 5, 2004 i doubt it's just software man lp2 is just 80 x 2 = 160 mins but here's what u could do..record via real time..just increase the pitch say ur using winamp u can download a plug in like fourier pitch/tempo control cuz i get to fit a lot of music than usual on MDs by just recording them faster n say each song have a surplus of bout 5-10 seconds on the disc it all adds up in the end to a lot of extra time left for more recording Quote Link to comment Share on other sites More sharing options...
