ipod vs. hi md
fretwork
I realize that everyone has their preferences, but here we go....
I need a device to record interviews (for school), band demos, and just to listen to at the gym. I've heard good things about the hi-md (besides some software glitches) but I also know there are some die hard ipod guys here too. Which is better for recording with the proper equipment?
thanks,
iPod = voice quality recording. If you want anything more, consider the iRiver HDD machines as well as Hi-MD. Despite faults I can pick with the iRivers, they may be more flexible in everyday use than Hi-MD (with recording and extraction to PC in particular) and these days they're definitely priced to sell. The H-120/140 machines have the same sort of gadgetty appeal as Hi-MD although the design is less slick, does practically everything and allows you to move material freely on and off the machine. Recording quality is OK and it will support anything up to PCM (the same as Hi-MD), yet there are some less intuitive aspects of recording on the H series. The H series also have a built in mic so there's no need to dispair if you left your mic behind... you can at least make voice quality recordings this way. If I were you, I'd try and get some "in the hand recording time" of both Hi-MD and the iRiver H.
  • 1 month later...
