mz-n10 dry batterie
EvilBad
first,sorry for my bad english...
i bought my md in the usa and now i have to buy a new adapter cause this one is not for europe.so now my md is working with the dry batterie...at the beginning it was no problem.the batterie was really fast empty and now with every new batterie i get the message low batterie.but its impossible.what can i do? THX for helping me dai
Welcome to the forums, Evil. Unfortunately, Kaotic's recommendation is a bit moot as the N10 takes a proprietary battery. If you suspect the battery is faulted, then I suggest you may want to seek a replacement. Perhaps you should look to our friend Audiocubes for such battery, or your local Sony parts center.
btw - Definitely get the right power adapter! :grin:
Hi there.
Here's the problem. The N10 uses a Li-Ion battery as its main power source, right? Well, that Li-Ion battery is 3.7v as compared to alkaline AA 1.5(ish)v.
What the unit does is when the AA battery pack is installed, the unit draws power from the AA first, and once the AA is exhausted, draws power from the Li-Ion. If the Li-Ion battery is drained... the unit will not work at all, full AA battery or not.
Kind of strange, but the only possible way that Sony could allow the N10 to utilize an AA battery pack along with its Li-Ion 3.7v 370mAh internal cell. There's a switching circuitry in there that changes the voltages over when using a different power source, I believe.
Units that utilize the NiMH gumstick type batteries (which are 1.2v 1000-1450mAh) are much more similar in voltage to alkaline AA's, so they can actually draw power from both batteries simultaneously. Unfortunately, as I have stated above, this is not the case with the N10.
I would get a voltage converter ASAP if I were you. Sony has some universal voltage (~100vAC-240vAC) adapters with 6vDCin, which should work great with the N10.
