erickMD Posted September 15, 2004 Report Share Posted September 15, 2004 Well...i bought the mz-nh1 md from japan...and i got the sonicstage in japanese...is there a way to change it to an english version? And I need to record a md in lp4 to my friend..using my Hi-md...how do i do that?? as sonicstage in japonese and i dont understand nething..help me plz Quote Link to comment Share on other sites More sharing options...
sxc Posted September 15, 2004 Report Share Posted September 15, 2004 Download the SonicStage version from www.connect.com It is in English and is fully functional. Just ignore the Connect music store if you don't want to buy music from it. Quote Link to comment Share on other sites More sharing options...
Qwakrz Posted September 15, 2004 Report Share Posted September 15, 2004 Eric. To record in MD format on your Hi-MD, use or format the Minidisc in MD mode, not Hi-MD mode & your recorder will behave as if it was a netMD unit & only allow SP, LP2 and LP4 recording. Quote Link to comment Share on other sites More sharing options...
erickMD Posted September 15, 2004 Author Report Share Posted September 15, 2004 hmm....thx im checking the site...i recorded a met in Net md...but it was in SP..and i want it in LP4...as i dont understand the sonic stage i dunno how to change it from sp to lp4 Quote Link to comment Share on other sites More sharing options...
erickMD Posted September 15, 2004 Author Report Share Posted September 15, 2004 well..i got the SonicStage...but it says when i try to instal: cannot install for this Windoes lenguage.... maybe bc my windows is Brazilian vers? Quote Link to comment Share on other sites More sharing options...
Aznsilvrboy Posted September 15, 2004 Report Share Posted September 15, 2004 Quote well..i got the SonicStage...but it says when i try to instal: cannot install for this Windoes lenguage.... maybe bc my windows is Brazilian vers?Go to Start>Control Panel>Date, Time, Language and Regional Options> Regional and Language Options>Advanced>change the language to Japanese and restart the computer. Then it'll work. SS japanese version requires the OS to be under the same language setting as it's language to operate and install. Quote Link to comment Share on other sites More sharing options...
erickMD Posted September 15, 2004 Author Report Share Posted September 15, 2004 Well...didnt work... Lets resume: I have Brazilian Windows SS Japanese version Installed I want a SS English version..but when I try to install the English SS...it says...cannot install for this windows lenguage Any1 has more helps? Quote Link to comment Share on other sites More sharing options...
Aznsilvrboy Posted September 16, 2004 Report Share Posted September 16, 2004 Quote Well...didnt work... Lets resume: I have Brazilian Windows SS Japanese version Installed I want a SS English version..but when I try to install the English SS...it says...cannot install for this windows lenguage Any1 has more helps?Oh sorry, i read your question wrong...anyways..what language setting is your brazilian winXP using right now? just follow my previous steps but instead change the language to English(USA) then try. Quote Link to comment Share on other sites More sharing options...
