toby Posted September 24, 2004 Report Share Posted September 24, 2004 Hi, My remote seems to be flakely (does not always work) since I plugged it in while the unit was already on. I removed the battery and it worked again but again today it does not seem to start the unit or function when I start the unit from the unit. Hey - this reminds me of the early days of the pc when you plugged in the mouse and crashed the system ! any advise appreciated ! ct Quote Link to comment Share on other sites More sharing options...
sxc Posted September 24, 2004 Report Share Posted September 24, 2004 Check that the hold button on the remote is not switched on? Quote Link to comment Share on other sites More sharing options...
toby Posted September 24, 2004 Author Report Share Posted September 24, 2004 Hi, that was it - somehow the hold button on the remote go switched back on. thanks!!!! Quote Link to comment Share on other sites More sharing options...
giacecco Posted September 26, 2004 Report Share Posted September 26, 2004 The hold button on the remote seemed off but it wasn't... completely. I was able to move between songs sometimes, and sometimes not, it seemed ad electrical issue. Well, I then started assuring me that the switch was "very off", and everything went fine :-) Giacecco Quote Link to comment Share on other sites More sharing options...
mutant1345 Posted September 26, 2004 Report Share Posted September 26, 2004 i had that problem too but i learned to check it more often but now my problem is that when im riding my bike sometimes the pmode button get hit and my music stops after one song and i cant put the old switch on because sometimes i skip a song so its really quite annoying when my player just Stops....and i have to restart thae player and all that Quote Link to comment Share on other sites More sharing options...
