Levanel Posted November 5, 2008 Report Share Posted November 5, 2008 (edited) Checked ebay.. none were for sale. If you've got any available for sale (or trade), please reply. Edited November 5, 2008 by Levanel Quote Link to comment Share on other sites More sharing options...
sfbp Posted November 5, 2008 Report Share Posted November 5, 2008 I did a little checking. But you're an old hand you probably know much better than I do. Are you sure you cannot use the LIP-4WM in the same slot? Maybe the form factor is different, I cannot tell from the pictures.I think I found one for 20 pounds in UK, will go back and find it if this is of interest. Oh yes, I remember, they didn't actually have stock. Quote Link to comment Share on other sites More sharing options...
Levanel Posted November 6, 2008 Author Report Share Posted November 6, 2008 I did a little checking. But you're an old hand you probably know much better than I do. Are you sure you cannot use the LIP-4WM in the same slot? Maybe the form factor is different, I cannot tell from the pictures.I think I found one for 20 pounds in UK, will go back and find it if this is of interest. Oh yes, I remember, they didn't actually have stock.Like this?Yeah, should've replaced mine ages ago.. now my N10 is a glorified MDLP/non-NetMD recorder. Quote Link to comment Share on other sites More sharing options...
sfbp Posted November 6, 2008 Report Share Posted November 6, 2008 updated original post Quote Link to comment Share on other sites More sharing options...
