doosmac Posted October 15, 2004 Report Share Posted October 15, 2004 when trying to open SonicStage I get this message"Omgjbox.exe has generated errors and will be closed by Windows. You will need to restartt the program" is there a way to fix this without reinstalling SonicStage? thank you Quote Link to comment Share on other sites More sharing options...
doosmac Posted October 15, 2004 Author Report Share Posted October 15, 2004 dang...I just did uninstall and reinstall but getting same error...I really need help now Quote Link to comment Share on other sites More sharing options...
Qwakrz Posted October 15, 2004 Report Share Posted October 15, 2004 So many things can cause this 1. HDD errors (run scandisk & get it to check for bad sectors) 2. Memory Errors (download a good memory tester & run it for the minimum of 1 pass) 3. Driver Conflict (good luck with this one) 4. Bad source file (if its downloaded try downloading again) But the most usual is V I R U S !!!! or Spyware Get your pc a good AntiVirus package & treat it to a run through with it, make sure it is updated before you do a scan. Its also advisable to download Spybot from the net & run that through your PC. Sorry but without any symptoms or error messages (including system spec's) all guesses at fixing it will be pure speculation. Quote Link to comment Share on other sites More sharing options...
doosmac Posted October 15, 2004 Author Report Share Posted October 15, 2004 thanks I'll do through scan of my computer when I go home tonight (I've been using it for about 2-3 month now so I don't think it's hardware) but is there somekind of preference file imbedded in system it self I can delete? I'm using win 2000 thanks again Quote Link to comment Share on other sites More sharing options...
bigdoodah Posted October 15, 2004 Report Share Posted October 15, 2004 I've had the same problem ever since installing those damned Windows upgrades yesterday... I can honestly say that it's not a virus-related problem, cause I reverted back to my configuration before the dreaded update and everything was fine again. I THEN upgraded my windows 2000, and it generates the same message as the poster's Anyone got around this problem? It pissing me off majorly Quote Link to comment Share on other sites More sharing options...
doosmac Posted October 15, 2004 Author Report Share Posted October 15, 2004 thank you thank you thank you... my problem happend right after that update too!!!!!!! :wink: I'll have to see if I can undo that update... Quote Link to comment Share on other sites More sharing options...
bigdoodah Posted October 15, 2004 Report Share Posted October 15, 2004 Keep me posted on the results Quote Link to comment Share on other sites More sharing options...
Christopher Posted October 15, 2004 Report Share Posted October 15, 2004 Uninstall via the directions in the NetMD faq and install again. :happy: Quote Link to comment Share on other sites More sharing options...
StarCapt Posted October 15, 2004 Report Share Posted October 15, 2004 I too got the "omgibox.ext" message after downloading latest Windows updates. Did a restore to previous point before updating to eliminate the problem. Quote Link to comment Share on other sites More sharing options...
doosmac Posted October 16, 2004 Author Report Share Posted October 16, 2004 I came home unstalled all Windows Hot Fixes dated 10/02/2004 reinstalled SonicStage and it finally works... :wink: all I can say is if you have Win2000 don't get the latest update Quote Link to comment Share on other sites More sharing options...
Seikeden Posted October 16, 2004 Report Share Posted October 16, 2004 confirmed. I just got it too. THX MICROSOFT :/ edit: gwar does anyone know exactly which hotfixes to uninstall? I have about 20 of em and I'm not sure which are the offending articles edit2: ok here are the offending items- - Security Update for Windows 2000 (KB841356) - Security Update for Windows 2000 (KB840987) - Security Update for Windows 2000 (KB841533) I uninstalled the hotfix for KB841533 last, and sonicstage is working fine now, without reinstalling. Not sure if its just that one. The updates are recommended by microsoft for install on all windows systems except for those running Windows XP sp2 This may be in need of an announcement somewhere as I suspect there'll be a lot of ungry 2000 and XP users in the next couple of days. Quote Link to comment Share on other sites More sharing options...
doosmac Posted October 17, 2004 Author Report Share Posted October 17, 2004 thanks Seikeden FYI I did a quick test and got it working with just these two removed - Security Update for Windows 2000 (KB840987) - Security Update for Windows 2000 (KB841533) Quote Link to comment Share on other sites More sharing options...
Latexxx Posted October 17, 2004 Report Share Posted October 17, 2004 Somebody should contact Connect.com's support and inform them. Quote Link to comment Share on other sites More sharing options...
doclloyd Posted October 17, 2004 Report Share Posted October 17, 2004 Thanks much for this post. I ended up having some SS issues today and removing those three hotfixes have my computer working again. Now, I need to contact connect support to figure out the computer authorization/de-authorization process. :-/ It's always something. Quote Link to comment Share on other sites More sharing options...
MarkA Posted October 18, 2004 Report Share Posted October 18, 2004 I too had this same issue today on Win2k (Omgjbox.exe error on start), but before finding this thread I uninstalled SonicStage and tried to re-install v2.2. My re-install attempt gets to "Currently Installing OpenMG Secure Module" and then aborts with an "Install Terminated" message, but no other explanation. Anyone else seen this issue? I've now tried removing the 3 listed MS Hotfixes above, doing the deep uninstall listed here, installing v2.0 from CD (which works fine) and then upgrading to v2.2, and just about every combination of the above (muliple times, with reboots) and still can't get past the termination of install for v2.2. Frustrating. I now sit at a working v2.0 SonicStage but would like to be back up to 2.2. Thanks, -Mark Quote Link to comment Share on other sites More sharing options...
doosmac Posted October 18, 2004 Author Report Share Posted October 18, 2004 can't you just intall 2.2 without updating?? I think when I had problem I just went straight to 2.2 (and I think I also uninstalled OpenMG items from "add/remove programs" before intallling 2.2) Quote Link to comment Share on other sites More sharing options...
StarCapt Posted October 19, 2004 Report Share Posted October 19, 2004 Mark A's experience is exactly my own. Can only use the SS 2.0 that came with the MZ-NH900. Very frustrating. Quote Link to comment Share on other sites More sharing options...
MarkA Posted October 19, 2004 Report Share Posted October 19, 2004 Interesting. Yes, I did try installing v2.2 directly (not as an upgrade) several times, with the same result. But, there was a KB article on Sony's site that suggested installing the original 2.0 CD version and then performing the upgrade in case some OpenMG file was corrupt. Same results. I had not noticed the uninstall item in add/remove programs for OpenMG before, but after reading the new post here, found and uninstalled that too, and then did the "deep uninstall" again and tried the install yet another time. Still the same result. Even after uninstall of OpenMG via the add/remove programs, there is still a ton of entries in the registry for OpenMG (some even result in regsvr32 errors on boot after deleting Sony directories). ...Another lame uninstaller that leaves garbage all over the place. I tried Sony support today. A 30 minute anticipated wait on the phone queue (not acceptable), and then I tried the support chat feature. The support person there had no clue and referred me back to the phone support. Still frustrated.... -Mark Quote Link to comment Share on other sites More sharing options...
