forge-aw Posted November 2, 2004 Report Share Posted November 2, 2004 i dj for hobby / pasttime / occasional extra earner. id like to be able to plug a device into the back of my mixer, and have it record the set that i play (having it worry about all recording levels, not faffing with it myself), it recording up to 3 hours non stop. plug it into my pc, pull off the sound as a file, an then split it up into chunks to burn to a cd. can any minidisc device do this? Quote Link to comment Share on other sites More sharing options...
Christopher Posted November 2, 2004 Report Share Posted November 2, 2004 Yes, but a NetMD/MDLP unit is not the answer. You'll need a Hi-MD unit for this sort of functionality. I would recommend the NH700 or NH900, but more importantly, what is your maximum budget? btw, welcome to the forums. Quote Link to comment Share on other sites More sharing options...
forge-aw Posted November 2, 2004 Author Report Share Posted November 2, 2004 i really wanted to top out about 200 quid, appears ill get one of those off ebay for my money.... hows does it connect to the pc Quote Link to comment Share on other sites More sharing options...
Christopher Posted November 2, 2004 Report Share Posted November 2, 2004 USB 1.1, unfortunately. It's still probably the best value for the price, espesically with the uploading. Quote Link to comment Share on other sites More sharing options...
forge-aw Posted November 3, 2004 Author Report Share Posted November 3, 2004 cool. seen a nh900 for sale for a little under 170, which i have my name on... should i expect it to come with a blank, or will i need to go out and get one? also, will i be able to use normal md media? Quote Link to comment Share on other sites More sharing options...
KJ_Palmer Posted November 3, 2004 Report Share Posted November 3, 2004 If it's boxed, brand-new etc. it should definitely come with a 1GB blank. Careful on eBay though, as those disks fetch a tidy sum in themselves... You can use normal MD media as well, though at reduced capacity (about 300 MB) Quote Link to comment Share on other sites More sharing options...
forge-aw Posted November 3, 2004 Author Report Share Posted November 3, 2004 its def brand new, its actually on amazon uk... looks like i'll be joining the ranks then.... Quote Link to comment Share on other sites More sharing options...
