Recharging the Sharp MT877
javertim
I purchased a Sharp MT877 from eBay a couple weeks ago. Since the model was released in the UK, mainly, I had to go out and buy an AC Adaptor that would fit the charging cradle ... Well, now I'm trying to charge the unit's NiMH battery -- Only nothing's happening. Unfortunately, my unit didn't come with a manual, so I am unsure if I have to press any series of buttons to initiate the charging process.
If anyone can render any aid whatsoever, I would be very appreciative.
Thanks! :-)
No need to press buttons to initiate recharge, unless you have the unit on; then you need to press "stop".
With the unit off, stick it in the charging cradle and the three lights should come on in sequence from left to right, this will continue for the duration of the charge. When the lights stop flashing, the battery is fully charged. If you are not getting the lights, recheck the connection between the powercord and cradle because the L-shape connector sometimes works itself loose when you put the md unit into the cradle.
Not to be like a mother, but to cover all bases; the negative end of the gumstick goes into the recorder first. Also, once a month you should open the battery slot and brush off the positive end of the battery. I find that lint has a way of working itself into the battery slot.
