gasaxeman Posted December 19, 2004 Report Share Posted December 19, 2004 I have had numerous problems loading any of the different versions of sonic stage onto my computer. I am running XP pro and have SP2 installed. I was not able to install before SP2 was installled. I am logged in as Adm. during attemepted software installs. Software worked on my old system fine.,same copmuter but completly new harddrives and all new software installs. I experience an error that says "Install launcher has experienced a problem and must shut down. Any fixes out there? Quote Link to comment Share on other sites More sharing options...
Christopher Posted December 19, 2004 Report Share Posted December 19, 2004 Welcome. :welcome: Are you running anti-virus protection? Firewalls? Quote Link to comment Share on other sites More sharing options...
gasaxeman Posted December 19, 2004 Author Report Share Posted December 19, 2004 I am running norton anti virus. I just tried with everything else turned off and the norton. Same error. Error signatureis as follows: AppName: Setup.exe ModVer5.1.26000.2180 AppVer 2.2.2.17250 Offset 00001010 Mod. Name NTdll.dll Quote Link to comment Share on other sites More sharing options...
Christopher Posted December 19, 2004 Report Share Posted December 19, 2004 Maybe it's because you have remnants of Sony software still there. Reinstall via the directions in the NetMD faq, except, install Sonicstage 2.3 from here afterwards: http://www.connect-europe.com/sonicstage Quote Link to comment Share on other sites More sharing options...
Weaves Posted December 20, 2004 Report Share Posted December 20, 2004 Kurisu, I did the unistall (per the instructions) and was going to upgrade to 2.2. However, I then saw that 2.3 was available for Europe. I was waiting for the North American update. Is the Euro version ok for N.A.? Thanks Weaves Quote Link to comment Share on other sites More sharing options...
Christopher Posted December 20, 2004 Report Share Posted December 20, 2004 Euro version works great on my computer. Quote Link to comment Share on other sites More sharing options...
gasaxeman Posted December 20, 2004 Author Report Share Posted December 20, 2004 I tried to install and it stops at the same point. Install launcher.Any other thoughts? Thanks Quote Link to comment Share on other sites More sharing options...
fin59 Posted December 21, 2004 Report Share Posted December 21, 2004 Hi ....I had the same problem on one puter.....I could not get past the install, always came up with error. Finally I got it to install by exporling the install disc and doing each program one at a time. It was a pain. Also do not forget to install drivers for the unit. That is how I got mine to work. :grin: Good luck! Quote Link to comment Share on other sites More sharing options...
atrain Posted December 21, 2004 Report Share Posted December 21, 2004 Quote I tried to install and it stops at the same point. Install launcher.Any other thoughts? Thanksthis happened to me three times & i was ready to ignore the update. try again at a diferent time of day. is it halfway through the third module by any chance? it happened to me using planetMG asia Quote Link to comment Share on other sites More sharing options...
