streaml1ne Posted January 11, 2005 Report Share Posted January 11, 2005 Got bored at work and was comparing encoded files to their wav counterparts. I noticed clips in one of the files I was screwing around with...http://canopus.syphen.net/hi-md/hisp-clip/Something in the encode/decode train is causing this. Since I can't open OMG directly in Audition I can't tell if SonicStage/codec is doing this or HiMDRender. *shrugs*Seemed interesting... Quote Link to comment Share on other sites More sharing options...
ROMBUSTERS Posted January 12, 2005 Report Share Posted January 12, 2005 if i had any idea what i was looking i would have made a more intelligent comment Quote Link to comment Share on other sites More sharing options...
Damage Posted January 12, 2005 Report Share Posted January 12, 2005 Got bored at work and was comparing encoded files to their wav counterparts. I noticed clips in one of the files I was screwing around with...http://canopus.syphen.net/hi-md/hisp-clip/Something in the encode/decode train is causing this. Since I can't open OMG directly in Audition I can't tell if SonicStage/codec is doing this or HiMDRender. *shrugs*Seemed interesting...←I think you could use Total Recorder or the like to record your WAV-out to your PC (or simply via using a mini to mini plug loop, even). Try recording the SS'd track directly and that should reveal where it's happening, the Decoding from SS or HiMDRenderer. Quote Link to comment Share on other sites More sharing options...
atrain Posted January 12, 2005 Report Share Posted January 12, 2005 if i had any idea what i was looking i would have made a more intelligent comment←well then why post at all? that counters really going up isn't it? Quote Link to comment Share on other sites More sharing options...
ROMBUSTERS Posted January 12, 2005 Report Share Posted January 12, 2005 (edited) well then why post at all? that counters really going up isn't it?←you just contradicted yourself with your own post, but in the future if it brightends your day i will not Edited January 12, 2005 by ROMBUSTERS Quote Link to comment Share on other sites More sharing options...
jadeclaw Posted January 12, 2005 Report Share Posted January 12, 2005 Something in the encode/decode train is causing this. Since I can't open OMG directly in Audition I can't tell if SonicStage/codec is doing this or HiMDRender. *shrugs*←I say, HiMDRenderer is innocent here, as it uses the DirectShow filters installed by SonicStage.I suspect, that Atrac got the scaling wrong by about 0.05 Decibels, as only the highest peaks got clipped.If the recorders codec suffers from the same problem can only be determined, when we have home decks with Digital out. Quote Link to comment Share on other sites More sharing options...
