hibs1875 Posted January 14, 2005 Report Share Posted January 14, 2005 I was in Currys today and saw my Minidisc player on display (NET MD MZ-NF610 Type S) and it said on it that it could store 5 hours of music on 1 standard minidisc.Can someone please tell me how i do it.Thanks Quote Link to comment Share on other sites More sharing options...
Kaotic Posted January 14, 2005 Report Share Posted January 14, 2005 by any chance, have you read the manual that comes with the unit? specifically on the topic of recording modes. if not, go do that now!!! if you still have no clue after reading thru the manual, people here will be happy to help you. Quote Link to comment Share on other sites More sharing options...
hibs1875 Posted January 14, 2005 Author Report Share Posted January 14, 2005 by any chance, have you read the manual that comes with the unit? specifically on the topic of recording modes. if not, go do that now!!! if you still have no clue after reading thru the manual, people here will be happy to help you.←Bought of a m. No box no manual etc. Quote Link to comment Share on other sites More sharing options...
sfphoto Posted January 14, 2005 Report Share Posted January 14, 2005 Bought of a m. No box no manual etc.←http://esupport.sony.com/perl/modelpage.pl...=EN&mdl=MZNF610this has the link to the user manual. If you didn't recieve software with your MD, you may need to dig around to look for the Sonicstage and driver software.I have the same one . . . record using LP4 to get 5 hours - Hit MENU, use the Fast foward arrow to go to R-SET, hit ENTER - arrow to R-MODE - you have the choice of SP, LP2 or LP4 - hit enter for your choice. Quote Link to comment Share on other sites More sharing options...
hibs1875 Posted January 15, 2005 Author Report Share Posted January 15, 2005 http://esupport.sony.com/perl/modelpage.pl...=EN&mdl=MZNF610this has the link to the user manual. If you didn't recieve software with your MD, you may need to dig around to look for the Sonicstage and driver software.I have the same one . . . record using LP4 to get 5 hours - Hit MENU, use the Fast foward arrow to go to R-SET, hit ENTER - arrow to R-MODE - you have the choice of SP, LP2 or LP4 - hit enter for your choice.←Cheers, got the disk and cables etc just no box and manuall.Thnaks for the help. Quote Link to comment Share on other sites More sharing options...
dex Otaku Posted January 15, 2005 Report Share Posted January 15, 2005 Note that LP4 is of pretty dismal quality. Quote Link to comment Share on other sites More sharing options...
dvallere Posted January 16, 2005 Report Share Posted January 16, 2005 I must disagree, Dex, I can't hear any difference between SP and LP4 for music. Quote Link to comment Share on other sites More sharing options...
KJ_Palmer Posted January 16, 2005 Report Share Posted January 16, 2005 Surely you can tell some difference between SP and LP4, Dvallere... Agreed that LP4 might sound acceptable to many - I use it sometimes myself even for classical music, but unless your 'SP' is actually fake SP -ie. LP2, I would have thought the difference would be plain, at least through reasonable ear/headphones... Quote Link to comment Share on other sites More sharing options...
aeriyn Posted January 16, 2005 Report Share Posted January 16, 2005 I must disagree, Dex, I can't hear any difference between SP and LP4 for music.←You're probably transcoding 128kbps MP3 to ATRAC. Of course SP and LP4 will sound very similar if you do this.Try making two separate recordings directly from a CD, one in real-time SP mode and one in real-time LP4 mode. Don't use SonicStage. Then have a listen, and tell me what you think.Although, if your headphones are not good enough, you may not be able to tell much of a difference... Quote Link to comment Share on other sites More sharing options...
ROMBUSTERS Posted January 17, 2005 Report Share Posted January 17, 2005 LP4 sounds very bad, although i say that after i bought a HiMD unit and actually had enough disc space to care... Quote Link to comment Share on other sites More sharing options...
dvallere Posted January 18, 2005 Report Share Posted January 18, 2005 I used to use SP on my old (pre-MDLP) recorder - optical out from my bookshelf system to the portable. Now I use LP2 or LP4 (with Sonic Stage) on my NZ-707. All my listening is done in the car - maybe five hours a year, I listen to a disc on my portable - and I don't notice a difference. Guess I should have qualified that.Though I may test this tonight. I'll report back. Quote Link to comment Share on other sites More sharing options...
ROMBUSTERS Posted January 19, 2005 Report Share Posted January 19, 2005 heh the worst thing you could probably do is look for bad compression in a song, then everytime its played you'll think about nothing but thatit keeps me awake at night :S Quote Link to comment Share on other sites More sharing options...
zerodB Posted January 23, 2005 Report Share Posted January 23, 2005 All my listening is done in the car - maybe five hours a year, I listen to a disc on my portable - and I don't notice a difference.←Yep, it's no wonder you don't notice a difference. Compressed audio is great for the car though. With all the other noise you get while driving, you don't exactly need high quality audio compression. Quote Link to comment Share on other sites More sharing options...
