mutant1345 Posted January 14, 2005 Report Share Posted January 14, 2005 hello, i have had a problem for the past week or so, and i may have posted on it already, i dont quite rememberi have an nh600d and for the past week + i have been expieriancing, my player coming to an abrubt STOP in the middle of playing back songsusualy i am walking when it happens, and the player seems to lose its place and does one of two things about a minute after cutting me off from listening1: displays a can not read or write error message and turns it self off, then reads fine after turning it back onor 2: returns to the begining of the disc, like i just started it up after taking the disc out!as you might know it is most annoying to be enjoying your music then have it cut off, and have to restart the song again or fast forward to the olace you were atif anyone has any suggestions on how to fix this or if it is something to do with the player please hlp me, it is really Pissing me off, i dont want to throw my player at the wallthancks in advance Quote Link to comment Share on other sites More sharing options...
ROMBUSTERS Posted January 15, 2005 Report Share Posted January 15, 2005 hmm your second problem sounds like the detector that senses if the lid is closed may be acting up, or your batteries are very lowthe first one, again the batteries could be the culprit, or it could be the laser head. try getting a cleaning disc or try playback from a different disc and see if it makes a difference Quote Link to comment Share on other sites More sharing options...
mutant1345 Posted January 15, 2005 Author Report Share Posted January 15, 2005 thank you for the reply but hpwever, i have tried playback with a full battery and i also have tried with a different minidisc, the problem occures the samethe sensor for detecting the lid being closed is omething worth thinking about howeveri have noticed that the lid is a little wiggely, is there any ways to tighten this lid?i have also cleaned the discs, and am wondering if a laser cleaner would be a good ideawell if anything, in the case i cant fix it i will prbly replace it with another protable music playerbut i feel this is a fixable issue..... Quote Link to comment Share on other sites More sharing options...
ROMBUSTERS Posted January 16, 2005 Report Share Posted January 16, 2005 try using a rubber band (temp) to hold it closed and see if that makes a difference Quote Link to comment Share on other sites More sharing options...
dex Otaku Posted January 16, 2005 Report Share Posted January 16, 2005 ROMBUSTERS said: try using a rubber band (temp) to hold it closed and see if that makes a difference←The old tricks are the best tricks. Quote Link to comment Share on other sites More sharing options...
ROMBUSTERS Posted January 17, 2005 Report Share Posted January 17, 2005 im curious if it actually worked. please reply with an update Quote Link to comment Share on other sites More sharing options...
mutant1345 Posted January 18, 2005 Author Report Share Posted January 18, 2005 ok i tryed the ruber band thing and for a while it seemed to work but my hopes were crushed when it hppend again quite obnoxious reallynow im debating between getting another one if i cant fix it.... or trying a hard drive player... any other suggestions?thanx for the help so far btw Quote Link to comment Share on other sites More sharing options...
?eter_ Posted January 18, 2005 Report Share Posted January 18, 2005 Uh..If you are living in the country where you purchased your 600, you can try getting Sony to repair it- If it's still under warranty they normally fix things regardless of what's wrong. In my experience with Sony,this doesn't hold true for optical blocks,but that doesn't seem to be the problem in your case.?eter Quote Link to comment Share on other sites More sharing options...
willykyu Posted January 18, 2005 Report Share Posted January 18, 2005 Hi!I have exactly the same problem, but on an NH1 this time!I'm listening to music, and somehow, it stops and reboots. I have to do everything from the beginning. I agree it's extremely irritating, and even with the 'disc memory' option on, it doesn't make any difference.So you're not the only one to have this issue on a Hi-MD unit! Quote Link to comment Share on other sites More sharing options...
mutant1345 Posted January 18, 2005 Author Report Share Posted January 18, 2005 well, if this issue is aswell on even higher end models that makes me less prone to getting another hi-mdand as for sending it to sony i would most likely have to pay a certain fee and ship it out aswell i believe, im wondering if this pay is worth it...and i dont have a sony store ANYWHERES near byi like hi-md a lot but i cant deal with music just up an quiting on meill try a few different things but im thinking about savin for something new.... Quote Link to comment Share on other sites More sharing options...
