Do U Want A Bigger Size Hi-md(>1g)?
Guest tony wong
do u want a bigger size Hi-MD(>1G)?
  1. 1. do u want a bigger size Hi-MD(>1G)?
    • no, 1G is too much for me indeed(I don't need that much for purely music storage)
      5
    • yes, 2G
      11
    • yes, 3G
      3
    • yes, 4G
      2
    • yes, 5G
      30
I have a PSP that I imported. SS 3.0 recognizes it, but won't transfer files to it. Supposedly my Duo Pro mem card isn't compatible since it isn't Magic Gate tech. Also, if I drag and drop the Atrac files to the PSP nothing happens.
Maybe there will be an update to the PSP firmware. I did test this out at my local coffee shop and it perfectly connected to the wireless network and checked for the latest firmware update. Nice.
I had a MagicGate MS 128 (Blue color), and SS2.3 did not work with it. Only with the white ones (older standard). Strange it was.
