daav Posted February 26, 2005 Report Share Posted February 26, 2005 Hey all, I wish i had read these boards long ago. I just picked up a mz-r500 on ebay for my girlfriend who is a journalist to use to record interviews and the like. Of course i checked arefully and was completely misled about the mic input that apparently isn't really there. Before knowing that, I went to test it with a cheap unpowered mic i had lying around and got a bunch of nothing for the effort. A few searches later and i see several posts mentioning that there is none. I saw that i could record from another MD player through a stereo 1/8th inch jack, so I couldn't figure out why the mic wouldn't work, and then saw this:http://forums.minidisc.org/index.php?showt...2292&hl=mz-r500So can someone help me avoid spending more money trying to get a decent (not too large) microphone that will work? Any advice links to current info etc would be great. Thanks! Quote Link to comment Share on other sites More sharing options...
Philgood Posted February 26, 2005 Report Share Posted February 26, 2005 (edited) Hi daav,although i think it's a little bit prizey but take a look here Edited February 26, 2005 by Philgood Quote Link to comment Share on other sites More sharing options...
daav Posted February 26, 2005 Author Report Share Posted February 26, 2005 Philgood said: Hi daav,although i think it's a little bit prizey but take a look here←Thanks for the suggestion, that looks to fit the bill, encouraging to see the write-up mentions this recorder as well. I'll keep that one in mind while looking for something a little cheaper as well. Daav Quote Link to comment Share on other sites More sharing options...
tigris Posted June 15, 2005 Report Share Posted June 15, 2005 Hi,I own an MZ-R500 from a few years ago. At that time I think I remember that I was able to record my voice using a cheap mic that came with a minicassette recorder, but after a few years I tried to record voice by using a mic to connect directly to the MD player, but it didn't work... after searching for a long time, I found this forum and this thread. So will this mic work with the MZ-R500? Any one have experience with this mic or MD player?Sony ECM-MS907http://www.minidisco.com/ecm-ms907.htmlMy main goal for recording is to record lectures, and perhaps piano and guitar music. Quote Link to comment Share on other sites More sharing options...
greenmachine Posted June 15, 2005 Report Share Posted June 15, 2005 You're out of luck, this recorder has no microphone preamplifier. You'll need either a different recorder with mic-in (preferably with sensitivity setting) or an external microphone preamplifier. Quote Link to comment Share on other sites More sharing options...
tigris Posted June 15, 2005 Report Share Posted June 15, 2005 greenmachine said: You're out of luck, this recorder has no microphone preamplifier. You'll need either a different recorder with mic-in (preferably with sensitivity setting) or an external microphone preamplifier.←Yeah, considering this I am also looking to buy a new recorder.Any recommendations for price/functionality?Also, are there alternatives to MD recorders for portable quality recording? Quote Link to comment Share on other sites More sharing options...
